Will an 88 TPI A4 Computer work in an M5?
Old Nov 7, 2000 | 03:25 PM
Yarnboy's Avatar
This ad was on the Classifieds page
"I have a brand-new computer with stock chip for a 1985-92 IROC/Z28 W/305 TUNED PORT INJECTION (TPI) I WILL TAKE $75 plus
shipping. This would cost over $250 new."
I called and he said it was off an 88 TPI AutomaticeI have an 88 TPI Manual..he had the 305 too..will it work? I know we have diferent cams..I didnt know if this changed anything within the ECM.
-Red '88 IROC 5 Speed 305 TPI w/3.08
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Grove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.90, 60 ft. 2.17, 1/8th mile 9.61(bald tires, Code's 34,36)
-Best MPH 92.7(bald tires)
Old Nov 7, 2000 | 04:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The computer should be a 7165 TPI computer for 86-89, but you will probably need a PROM for a 5-speed car.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 8, 2000 | 08:37 AM
Flfinn's Avatar
Car: GTA '88
Engine: 420 Dart SHP
it'll work, but the shift up light will be lit when cruising.
-88 GTA 305TPI/T5, 3.45 posi, minor mods (slightly ported+portmatched heads, base, plenum, multiangle valve job), Haltech E6GM, ~more to come. ET 15.2@93mph. www.helsinki.fi/~kjilehto
Old Nov 8, 2000 | 12:12 PM
Yarnboy's Avatar
Well the PROM I have now is for my car..Can't I just use it? Also, is there a sure fire way to test if the ECM is bad? The shift light will always remain lit even if I have the right PROM? DAMNIT!! I am getting a new ECM to try and get rid of the SES light!!..I don't need another gay orange light telling me something..
-Hypertech Chip
-Hypertech Airfoil
-Gutted Air Box
Old Nov 9, 2000 | 06:31 AM
Vader's Avatar
The "SHIFT" lamp is only wired on manual transmission cars. The ECM uses the same output terminal to operate the "SHIFT" lamp on manuals or the TCC relay on automatics. The difference is in the vehicle, not the ECM. The ECM uses a different PROM to operate the output differently on each car, but he hard wiring difference is in the vehicle.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
loud91rs
Oct 5, 2015 10:05 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
