What is detonation?
Old Aug 30, 2003 | 04:13 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
What is detonation?
What exactley is detonation and how does it take place in a engines performance?
Old Aug 30, 2003 | 04:49 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
to be all technical and crap:
Detonation is the after effect of a amplification of pressure waves during the combustion process when the piston is close to tdc. detonation will occur will the heat & pressure in the combustion chamber cause the air/fuel mixture to autoignite which produces multiple flames instead of a single flame. when the multiple flames collides it creates a high pressure in the cynlinder hence a knock or "pinging" noise.
thats a generic explnation, do a search here if you want a further more explanation.
Old Aug 30, 2003 | 10:13 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
to add, it can potentially catastrophically destroy your engine within seconds, depending on severity. it has a distinct sound when it happens too. kind of a very sharp metal tick i guess
Old Aug 30, 2003 | 11:50 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
so the phrase "pinging valves" is professionally called Detonation?
Old Aug 31, 2003 | 12:51 AM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
the more "street" name for it is called spark knock
BBSDesigns
Sep 22, 2015 03:08 PM
shutch
Jun 14, 2001 03:20 PM
Yelofvr
Dec 20, 2000 05:05 PM
Jess Cooper
Jul 24, 2000 01:31 AM
