What is this?
Old Sep 3, 2003 | 08:44 AM
imstress's Avatar
What is this?
Can anyone tell mewhat this is and if I need it?
car is a 86 T/A 305 4bbl AC delete. smog delete.
Old Sep 3, 2003 | 08:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is the baro sensor. It measures ambient pressure - obviously, intake manifold vacuum is the difference between this and the MAP reading.
If you still have the ECM, you need it.
Old Sep 3, 2003 | 10:09 AM
imstress's Avatar
looks like it use to have something on the vacuum type fitting? maybe a filter, can it be tested to see if it is working?
Old Sep 3, 2003 | 10:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is the baro sensor. It did not have anything attached. There may at one time have been a foam filter of some sort inside the thing that looks like a hose would go there. It measures atmospheric pressure.
I know of no good way to test it.
Old Sep 3, 2003 | 11:41 AM
Vader's Avatar
The only way to test it is by monitoring the output voltage (0-5VDC) and a known pressure. I have pressure/output tables for MAP sensors, but unfortunately, not for a BARO sensor.
Old Sep 3, 2003 | 12:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the info! I had always assumed baro sensors were like map sensors (as regards the vacuum line).
For what it's worth, http://www.sunpro.com has a great deal in their garage sale link (under test & tune) for a sensor tester that can read MAP and MAF sensors. (It was replaced by Sunpro with a more advanced tester that reads even more sensors...)
Old Sep 3, 2003 | 01:16 PM
imstress's Avatar
Thanks for the information. I'm just trying to clean up under the hood, and get rid of unnecessary stuff like wiring for AC ans fuel injection which I don't have. So if I don't know what it is, this is a great place to find out before I make a bad mistake.
