Headlight having a joke on me
Old Sep 3, 2003 | 02:19 PM
nitrospaz19's Avatar
Car: 86 Trans Am.....
Engine: 305 T.P.I
My driver side headlight seems to be having fun with me. We used to think it was the relay which I am told was only on certain trans ams. But the old one was shot and cracked so I bought a new one and it fit perfectly in place. I tried the lights and got nothing. While getting pissed later on that night I hit the button and they both went up. Turned it off and right back on and didn't work again.
Well since I have added that relay it is harder to turn the manual *** to get the light up. Well it feels like working when it wants to and that is driving me crazy. I think a cleaning of the connectors would be the solution because they have like grease on em from 17 years ago when the car was born. Any advice as to this?
Any? Any Help at all...
Thanx
Tom
Old Sep 3, 2003 | 02:28 PM
BADBIRD009's Avatar
sounds like your switch has got a short in it, you will need to replace it.
Old Sep 3, 2003 | 04:18 PM
Engine: 305 T.P.I
lol sounds easy enough but in my experience with this car so far nothing is easy. So how do I do this and is it expensive? On a tight budget for a little while. Thanx for the help
Old Sep 5, 2003 | 09:51 AM
BADBIRD009's Avatar
its not expensive. you can get one from anywhere that sells third gen interior parts. should be about 15 bucks or so, i believe. you might even find one cheaper on ebay.
the switch is on the dash. you dont need to take the whole dash off just the little compartment thing that the switch is in. behind it are two screws, then take those out. put your new switch in and wire it the same way the old one was.
Old Sep 5, 2003 | 09:57 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
And since it all uses wire harnesses it'll be easy. i've been in mine fairly often.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
