Need help from mini-ram owners
Old Nov 9, 2000 | 06:42 PM
BlueBottleJunky's Avatar
ok.....bought me a complete mini-ram...have my heads picked out (58cc Canfield 195s)....just wonderin how radical I can go on my cam? I always thought bigger was better (at least thats what the girls said) until I got reading up on them. The shortblock is factory (38k) and if my figures are correct, compression should be around 10-1 with the 58cc heads. I'm thinking somewhere around 224°-226° @ 50 with a mid 500 lift. Would I be happier with a bit more duration or am I on the right track? Thanks in advance. PS...weekend warrior more so than a daily driver.
Old Nov 10, 2000 | 11:11 PM
come on....help me out guys....
Old Nov 10, 2000 | 11:17 PM
mtx28's Avatar
if weekend warrior.. then i'd go for a cam in the 230 range, but at the same time get a torque converter with a higher stall speed(you'll have to ask someone else as to whether to get a lock up or not) to work with the cam, because a big cam with a low stall speed converter = no good. im not sure if any cam is specifically made to work with mini ram's or not, but i'd imagine that your power range is btw 2500-5500, so get the cam & converter to work within that range... good people to talk to are the tech guys at summit (www.summitracing.com), who are very helpful in helping you pick out what you need
Lbibb
May 5, 2016 12:00 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
