Quick question
Old Nov 11, 2000 | 12:21 AM
JPrevost's Avatar
Car: 91 Red Sled
Quick question
I don't know what stall converter I have. How can I tell? I'm going to be doing an engine swap and so I'd like to know if a stock conv. would make the car stall or what. The engine isn't going to be all that crazy since I need to pass NJ emmisions with it. I haven't desided on a cam shaft but the one in the f-body caprice engine offered from sdpc is probably the closest. Please help, if you think I need a new converter where is the best place to get one for a 4L60?
, Jon (91 RS too many mods to list)
Old Nov 11, 2000 | 07:29 AM
ede's Avatar
ede
basically your stall speed is where the car has to move forward or the engien dies. hold the brake and give it some gas, like you're doing a burn out and watch the tack. the rpm will be your stall speed. car weight and other factors have a bearing on stall speed, most aftermarket converters don't reach the advertised stall speed in a thirdgen.
-=ICON MOTORSPORTS=-
1st & 3rd
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
