Guy's I need intake and exaust gaskets, which ones? and A few more ?
Old Nov 4, 2000 | 02:35 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Okay There is a little oil around the the 3rd bolt on the pass side of the intake, I guess that means it is leaking, I have felpro gaskets on there now and they went on when the new motor went in about 3 monthes ago. So what kind of intake gaskets should I get? ones with exaust crossovers? Can someone give give a brands and a part number, there a few diffrwent ones for small chevys, I have the 85 and older gm replacment motor with a edelbrock intake. Second ? what kind of header gasketsa should I get? do I have round or square ports? I ahve the edelbrock headers, that where for a 305.I was thinking the earls ones. Thanks alot
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 4, 2000 | 05:09 PM
Marc 85Z28's Avatar
Check your CamaroZ28 post
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, Transgo shift kit, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
Old Nov 4, 2000 | 05:10 PM
CamaroZ_85's Avatar
earl's headrer gaskets are great...i havent had a problem in about 5k miles and ive never re-tightened the bolts either fel-pro gaskets always work fine for me...i just put a new intake on today but i cant remember the p#, sorry
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Nov 6, 2000 | 08:28 PM
BLACK Z's Avatar
Car: 86 Z28
btt
Old Nov 10, 2000 | 06:30 AM
BLACK Z's Avatar
Car: 86 Z28
Does anyone know what kind of ports my heads and headers have? thanks And does anyone else have anyinput on the other ? thanks alot
Old Nov 12, 2000 | 12:11 AM
BLACK Z's Avatar
Car: 86 Z28
btt
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
Street Lethal
Aug 14, 2015 08:25 PM
Jake_92RS
Aug 11, 2015 10:39 AM
