PROBLEM...HELP!!!
Old Nov 14, 2000 | 01:34 PM
Stuart S's Avatar
PROBLEM...HELP!!!
car problem
'86 IROC w/LG4...I went to start it.....everythings fine at first...
Then I go to kick it down, and i hear this "clank clank ***** ***** clank"
sounds like its from front of block, by belts....
The belts are not wobbling, and are tight.
WHAT'S WRONG?
Stuart S
1987 Trans Am LB9/WS6
1986 Camaro IROC-Z
OEM Posterchild of the soon to be Infamous Long Island Crew
Old Nov 14, 2000 | 01:50 PM
Stuart S's Avatar
By the way, it has just under 75,000 miles and the smog pump is 3-4 months old...
Old Nov 14, 2000 | 02:56 PM
Birmass's Avatar
You're gonna have to be a little more specific. It could be any of the pullies, or the water pump etc. If it seems to be running fine, start it up again and find where it's coming from. Then get back to us. We aren't psychics
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
Eats LS1's with a 2.73 open rear and 2 1/4 stock catback
My Formula
Old Nov 14, 2000 | 02:57 PM
Birmass's Avatar
If the car is not runnig anymore. I would venture a guess that your timing chain has some problems.
Old Nov 14, 2000 | 03:25 PM
MR. JORDAN's Avatar
I bet it's your timing..I've heard this clinking before and thats what it was.Check your timeing,it plays a huge roll in the function of your engine...
Old Nov 14, 2000 | 03:37 PM
Rogue Leader's Avatar
Car: a furry tractor
stu I know that noise.. Thats the teeth off your cam sprockets clanking around inside the timing chain cover. Time for a new one. dont run it anymore btw, you'll only do more damage. Hopefully you didnt break anything else... LOL have fun taking off ALL your accessories.... And you'll need a puller for the balancer. its SO MUCH fun....
--Rogue Leader
AOLIM: TransAmWS6
NY Region SCCA #2 ESP
Old Nov 14, 2000 | 03:41 PM
Birmass's Avatar
Don't worry Stu. I have a balancer puller and we can do it in an hour or two. I've done it about 10 times myself. Actually we could do it in your parking lot!
Rogue - Cam sprockets????? There aren't sprockets on eth cam. You mean the gear???
[This message has been edited by Birmass (edited November 14, 2000).]
Old Nov 14, 2000 | 04:29 PM
thats what i meant...... Many people call em cam sprockets....
Old Nov 14, 2000 | 04:37 PM
Stuart S's Avatar
It idles just fine, and it restarted 3x, so I doubt its a timing issue
Old Nov 14, 2000 | 06:10 PM
Steves ZZ5's Avatar
Did your harmonic balancer seperate? Sometimes the outer ring portion of the balancer will drift back against the timing chain cover and cause some nasty rubbing/clanking sounds. Take a look there. It's pretty easy to tell if its seperated.
Steve
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
Old Nov 14, 2000 | 06:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have experienced a situation where an alternator did that... something came loose internally on the armature; the alternator still worked; but it made this bizarre noise all the time, especially when revved quickly, and it had a noise that kept on after the belts had visibly stopped.
You may also want to take a look at the fan clutch, and make sure it hasn't died and is allowing the fan to wobble around and hit something.
Old Nov 14, 2000 | 08:25 PM
Vader's Avatar
Stuart,
Cut the problem in half - disconnect all the drive belt(s) and restart. If the problem still exists, you've just eliminated all the accessories. If the problem disappears, you only have four or five accessories to check out.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 14, 2000 | 08:47 PM
Stuart S's Avatar
Started it again...it purrs like a kitten...weird.
Old Nov 14, 2000 | 09:27 PM
Bort62's Avatar
Oil circulation Up to the top of the Motor Prolly then
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
