connecting rod size?
Old Nov 13, 2000 | 08:12 PM
ede's Avatar
ede
what is the big and small end size on a SBC rod? out of round and diameter tolerance ? thanks
-=ICON MOTORSPORTS=-
1st & 3rd
[This message has been edited by ede (edited November 13, 2000).]
Old Nov 13, 2000 | 08:16 PM
Jester's Avatar
The biggest I've ever heard of was about 18", but it was surgically enhanced. 2" I think is the smallest (thats gotta suck). if it's out of round I think you should see a doctor and/or try to get a role in a porno video.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
Old Nov 13, 2000 | 11:21 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
If you look at the crank end of the rod sideways you will see that one side is offset more to get it into the center of the journal more.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Nov 14, 2000 | 08:11 PM
Vader's Avatar
Jester,
Wrong crank, er, rod...
Paul,
I think Ed was asking about measurement and tolerance.
Ed E.,
If that's what you wanted, a "typical" SBC rod from anything after 1968 should have a crank journal bore finished at 2.225", a wrist pin bore finished at 0.9375", and a center-to-center distance of 5.690".
Early "small journal" SBCs had 2.125", 0.9375" and the same 5.690" center distance.
Generally, if the journal bore is worn, the rod is a paperweight.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 15, 2000 | 03:28 PM
md's Avatar
md
.0002" out of round and I have the journal end re-sized and the pin bushed or pitch them. Depends on the build.
After-market rods are so cheap any more, it's usually worth while to get new rods for anything other than a stock rebuild. To have rods re-conditioned will cost nearly as much as an after-market I-beam.
C409
Jan 21, 2016 08:29 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Reborn756
Sep 4, 2015 03:42 AM
knight72
Aug 10, 2015 09:32 PM
