got a g-tech have questions
Old Sep 12, 2003 | 10:20 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
ok i used the g-tech today 3 runs the best being a 14.7 at 88 something mph, and a 0-60mph time of 5.7 these numbers seem high to me what do you guys think my car should be at least running? also on this run it started to bog on the top of 4th gear
i have the following
305 .20 over
214/220 .452/.465 270/276 adv duration roller cam
WP S/R torquer 305 heads
Edelbrock Performer intake
Headman Coated Shorty Headers
Gutted Cat
3" edelbrock RPM series cat-back
5-Speed
3.73 Posi rear
Q-jet CCC with free mods
hypertech thermomaster chip/160 degree thermostat
Old Sep 12, 2003 | 10:58 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
The "bog on the top of 4th gear" sounds like it may be running out of fuel to me. I hear the that Q-jet has a relatively small bowl for the CFM it can flow, you may be running it dry.
I'd look into recurving the ignition for faster advance if your distributor is in fact in charge of the advance curve (not the ECM). I agree with you that your numbers sound a little slower than I'd expect.
The G-techs are usually a little optimistic if anything from my experience, by a couple tenths.
Old Sep 12, 2003 | 11:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If he's got a CCC carb the ECM should be controlling timing. Adding a little base timing might help.
Old Sep 13, 2003 | 12:44 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
well it doesnt bog all the time, i made 3 passes 2 it didnt bog but spun through 1st, it's the mystery bog
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
