O2 sensor question/problems?
Old Nov 15, 2000 | 10:57 AM
Andy89RS's Avatar
After I installed an air/fuel ratio guage in my Camaro I noticed that the readings would hesitate, and generally swing back and forth a whole lot slower than they should. I figured that meant the O2 sensor was going bad so I got a new one. Since I have headers and am running a cooler thermostat, I got a heated O2 sensor. I wired up the heating leads to power, and plugged in the sensor lead. Now, the air/fuel ratio guage is acting more like a voltmeter, it holds steady and just makes small movements when I turn on the a/c or do something else that also makes the voltmeter move. To add a bit more strangeness to it, every once in a while, if I'm at full throttle for several seconds at least, the guage seems to start reacting as it should. I double checked all air/fuel guage connections, they're all good. Did I get a bad sensor that's letting the heating coil ground through the sensor itself? Any other ideas?
Old Nov 15, 2000 | 11:30 AM
Blade's Avatar
What are you expecting out this guage ? The 02 sensor is nothing more than a switch that tells the ECM if the AFR is lower or high than 14:7. It's not gonna give you accurate readings. IMHO the guage is just a nice looking gadget when hooked up to the stock 02 sensor
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.dhs.org/Members/...dmondIndre.htm
Old Nov 15, 2000 | 12:19 PM
Andy89RS's Avatar
On an EFI car, the guage should make a fast swing from lean to rich as the O2 sensor detects the rapid mixture changes the ECM is making. If it's staying in one spot, something is wrong.
Old Nov 15, 2000 | 12:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Andy, have you tried unhooking the supply to the oxy sensor's heater, to see if the gauge changes?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 15, 2000 | 07:47 PM
Andy89RS's Avatar
I'll probably do that this weekend, I just wanted to get every possible cause before I start so I don't do one thing and then sit there wondering what else it might be. I like to know all possibilities beforehand...
Old Nov 15, 2000 | 09:21 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by Andy89RS:
... I got a heated O2 sensor. I wired up the heating leads to power, and plugged in the sensor lead...
Andy, Am I reading this right? You wired two of the leads to power and the third to the sensor circuit? One of those two leads is ground and the other power. Both are the same color, so it matters not which you wire to power or ground.
Old Nov 15, 2000 | 09:39 PM
Andy89RS's Avatar
Oops, it does look that way when I re-read it. I did hook it up the right way though, one to power, the other to ground.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
