Fuel Injector question.
Old Sep 15, 2003 | 02:54 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am a little confused about the ratings of injectors.
I just put a set of 26# 99 LS1 injectors on my 95 LT1 to replace the 24# ones I had.
The question is, are these 26# injectors rated at 58psi or 39psi.
I read that they are 26# @ 58psi, which become 22# at 43psi.
Now, some people are saying that all injectors are rated at 39psi.
Did I screw myself by getting these 26# injectors?
Old Sep 16, 2003 | 08:03 AM
Vader's Avatar
Uh, No. Bosch rates most (but not all) of their injectors at 300KPa. soem are rated t 36, 39, 44 or 45 PSIG. Other manufacturers use different pressure ratings for flow rate testing.
Yes, you may not have the injector flow that you think you do.
Old Sep 16, 2003 | 10:44 AM
Zepher's Avatar
Thanks Vader.
These are stock injectors. Is there a part number reference I can use to check the specs on these injectors?
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
