emission failing, non thirdgen
Old Sep 17, 2003 | 04:13 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
guys have an 88 plymouth voyager with the 3 liter v6 in it, and it keeps failing on the NOx what would cause this? they suggested EGR valve we installed a new one and it still failed, help as the emission laws are strict now and i need to use this car
Old Sep 17, 2003 | 04:53 PM
demonchild's Avatar
usually the egr or timing. check the timing.
Old Sep 17, 2003 | 06:27 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Also remove the intake and clean the hell out of it. Especially in the area of the egr. If the tunnels running to the egr are filled with crap it can give high readings. I assume you've already done the basics like O2 sensor, plugs, fuel filter, etc, etc.
Old Sep 18, 2003 | 06:04 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
a chart that i have points to several problems that it could be:
1-egr system
2-loose missing vacuum lines
3-ignition timing
4-block or stopped up exhaust
5-fuel mixture to lean
6-carbon builup in the cylinders
7-catalytic converter
I am not a guru this is just off of a chart i use to help figure out why one wont pass the dreaded test----good luck
Old Sep 18, 2003 | 12:28 PM
Vader's Avatar
C'mon. You know the rules. Non-ThirdGen? - Non-Thread...
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
MoJoe
Sep 15, 2015 12:50 AM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
