305 crank question with a twist
Old Sep 17, 2003 | 04:57 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
https://www.thirdgen.org/techbb2/sho...hreadid=187367
i read that for the 350 crank in a 305..
here's what i want to do. i have the 305 out of my 84 z28, and i'm planning on scrapping the block.
can i use the crank and rods in a 350? i'm planning on getting new pistons, and will have everything balanced, if the crank doesn't need ground.
any ideas? advice?
Old Sep 17, 2003 | 05:16 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Yes the stroke and jurnal size is the same with the 350 and 305 you can enterchange them fine.
Brian
Old Sep 17, 2003 | 05:33 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
cool deal, thanks a lot
Caspar
Jun 19, 2016 11:19 PM
gta90
Sep 15, 2015 04:00 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
