car continues to run after key is removed
Old Sep 19, 2003 | 03:33 PM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
i know what your gona say, but its not carbon deposits or high rpms or idle settings. all 8 cylinders are fireing perfectly and normaly for about 10 seconds after i take the key out. i think the only thing stopping it from running forever is being starved of fuel. everything else shuts down (fuel pump, fans, radio) but for some odd reason now my engine just keeps going uninterupted. it has a nice smooth idle and shuts down nicely after 10 seconds, its almost kind of cool, but since that happend other wierd things are happening. for some reason every now and then my fuse that protects the interior lights/horn keeps blowing. i think mabey when the engine keeps running on, the extra power its produceing mabey sends a surge of power through this circuit, any ideas?
Old Sep 19, 2003 | 03:54 PM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
I would say you most likely have a short somewhere. Check the wiring would be the first order of business.
Have you made any recent modifications or changes?
When I first put on an MSD box on my wifes 72 Skylark, it exhibited the same symptoms. Had 2 of the wires crossed on it.
Old Sep 20, 2003 | 05:01 PM
Psyte's Avatar
all of this started when i washed my engine. but i noticed my ignition cylinder is loose and sometimes sticks when i turn it off. yesterday i floored it down a road and i started smelling burnning wires..... man i think im gona need an electrical overhaul soon
Old Sep 20, 2003 | 10:33 PM
88TAJeff's Avatar
Car: 88 T/A
Jeez Psyte, MORE burning wires?
Old Sep 21, 2003 | 07:10 AM
Damon's Avatar
Yeah, you need a new ignition cylinder in the steering column. Had that problem recently with an 85 IROC but it would run FOREVER with the key removed (since it has a mechanical fuel pump and carb).
Old Sep 21, 2003 | 06:10 PM
Psyte's Avatar
how much does it cost to get that replaced? do you think this is a job i could do myself? last night i turned my radio on by turning the key backwards and again i smelled burning wires, but i saw no smoke.... man one of these days my car is gona go up in flames
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
