Fuel pump help!
Old Sep 20, 2003 | 01:47 PM
Gabe898's Avatar
Fuel pump help!
im not getting power to my fuel pump, i have replaced the relay, checked fuses and still no power, but when i run direct power to my (ALDL) on terminal G in it turns on, so whats next??
Old Sep 20, 2003 | 01:54 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I believe the fuse is up near the battery on my IROC, might be there on yours as well.
Old Sep 20, 2003 | 02:09 PM
Gabe898's Avatar
Yea i just check it....
Old Sep 20, 2003 | 03:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Is the relay working? If not, you'll need to check wiring back to the ECM...if okay, I'd suspect ECM is not firing the relay.
Do a search, you'll find the schematics posted, verify you have power to the coils of the relay when the key is on...this will only last for about 2 seconds...so either pu the meter where it's viewable, or have a friend turn the key.
Old Sep 20, 2003 | 04:31 PM
Gabe898's Avatar
well...i got it going, the wire harness on the relay was bad thanx for the help!
Old Sep 20, 2003 | 04:33 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Cool...and welcome to thirdgen.org
Old Sep 21, 2003 | 04:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Glad you got it fixed, Gabe! I had a similar problem; the ring terminal for the fuel pump fuse, at the positive junction block, on the passenger side of the radiator support, was the cause of my headache. The wire corroded and became intermittant.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
