What size chambers on heads?
Old Nov 20, 2000 | 08:45 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
On the S/R torquer's which chamber size is the best for an 87 305 Tpi, the 76 cc or 67cc. Or do they make one smaller for the 305?
87 Z28 305 TPI, Auto, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47
Old Nov 20, 2000 | 09:10 PM
MikeC.86Roc's Avatar
I think the stock heads on a 305 are as low as 58cc.. I know the new zz4 uses 58cc chambers, and thats for a 350. I have a set of AFR heads with 58cc chambers that I am going to use on my 350. Unfortunately, compression will be way high for a street motor so you might want to consider that when you get your heads. Dished pistons and flat tops are another consideration. A dished piston or one with large valve reliefs can lower compression. But why not do it with chamber size instead? If I could go back and do it again, I would make the chambers larger in my heads!! :-(
Old Nov 20, 2000 | 09:36 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Ok I went to JEG's and found that the 305 torquers are only 58 cc is this the way to go or will the 67cc's work. What is the difference?
[This message has been edited by new87 (edited November 20, 2000).]
Old Nov 20, 2000 | 10:24 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
The larger combustion chambers are for larger engines, who can keep compression up with larger chambers due to the greater cylinder volume. With the 305 and the 67cc heads your compression will get shot to hell, and your power will suffer. The 58cc heads will keep your compression ratio up where it needs to be.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Nov 21, 2000 | 09:13 AM
Polecat's Avatar
305 use the 58cc, on a 350 get the 67cc heads. You'll love the power addition of the S/R's.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
CRFred
Feb 7, 2016 11:39 PM
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
