What Flywheel to use
Old Nov 20, 2000 | 03:29 PM
Larrys T/A's Avatar
Car: 1988 Pontiac Trans Am
I have a 350TPI with a 5speed. I need to know does the flywheel need to be balance or not. Please help
  • 1987 T/A 350tpi, 5speed,SLP Headers,Stock 1995 Z28 Muffler, Gutted Cat,Compucam 2030 429 452 & 204 214,TbBypass,Ported Plenum,AFPR, SLP LCA,SFC. 13.86@96.4 with 1.96 60ft
Old Nov 20, 2000 | 03:33 PM
snakeskinner's Avatar
305 and 350 are the same as long as you are using a similar yeared engine. later models are externally balanced and earlier models are internally balanced. there is no way to have the flywheel balanced correctly because you have no idea how the engine rotating assembly is balanced.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
Old Nov 20, 2000 | 04:31 PM
ede's Avatar
ede
you ought to give a little more information about what you have or what you're doing to get a better answer. kyle is correct keep the flywheel the same year as the engine and you shouldn't have any problems.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 20, 2000 | 04:32 PM
Larrys T/A's Avatar
OK Snakeskinner Thanks for the info. What about the harmonic balancers are they the same (305 350).
Old Nov 21, 2000 | 01:08 PM
md's Avatar
md
I've been trying to figure the damper issue out myself for quite some time. Lingenfelter makes the statement in his book that the post '86 one piece seal crank engines require a different damper. I don't see why they woud but you should check it out prior to getting a standard neutral balance damper. I just dont know for sure. Anyone???
Mike
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
