Throwing codes after head and cam swap. How do I find out which codes?
Old Nov 21, 2000 | 08:09 PM
Mike '91 Z28's Avatar
What was the procedure to find out what were the last few codes thrown by the computer??
Old Nov 21, 2000 | 08:20 PM
rondubbs's Avatar
| 1 2 3 4 5 6 |
| 7 8 9 10 11 12 |
DISPLAYING THE TROUBLE CODES
Run a wire/hairpin from Pin 6 to Pin 12 with the ignition off (although on later cars it should be from Pin 5 to Pin 6), then turning the ignition to the on position without starting the engine will flash the "Service Engine Soon" light in the following sequence: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause Following this "12" code repeating three times will come any trouble codes stored, flashing each of them three times. If you do not see the "12" flash three times, your diagnostic circuit is defective.
Some vehicles will display stored trouble codes, then "12" again, followed by energizing "most system controlled relays." The fuel pump relay will not energize. The idle air control valve will fully extend to enable checking minimum idle speed
[This message has been edited by ron rizzotti (edited November 21, 2000).]
Old Nov 21, 2000 | 09:00 PM
Vader's Avatar
Ron,
I don't know what you define as "earlier" or "later" cars, but all ThirdGens would fall into the "later" category by your description and diagram.
The pin sockets on the ALDL are actually identified with letter designations intead of numbers. The scheme is as follows:
I just thought I'd clarify that for ThirdGens, since I'd just hate to see someone trying to ground out a serial data bit stream.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Nov 21, 2000 | 09:28 PM
I done what you did and I'm slighly confused (I think). How long should I be counting the flashes and pauses?
Here's what I got:
x = flash
- = pause
-- = long pause
xxxx-xx--
xxxx-xx--
xxxx-xx--
xxxx-xxx--
xxxx-xxx--
xxxx-xxx--
x-xx--
x-xx--
x-xx--
xxxx-xx--
xxxx-xx--
xxxx-xx--
xxxx-xxx--
xxxx-xxx--
xxxx-xxx--
x-xx--
x-xx--
x-xx--
xxxx-xx--
xxxx-xx--
xxxx-xx--
xxxx-xxx--
xxxx-xxx--
xxxx-xxx---
x-xx--
x-xx--
x-xx--
xxxx-xx--
xxxx-xx--
xxxx-xx--
xxxx-xxx--
xxxx-xxx--
xxxx-xxx--
x-xx--
x-xx--
x-xx--
Anyone know what numeric codes these are? Thanks.
[This message has been edited by Mike '91 Z28 (edited November 21, 2000).]
Old Nov 22, 2000 | 09:25 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
42 and 43.. the 12 just means the diagnostic funtion is working properly.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
apie2546
Aug 10, 2015 05:43 PM
