I just realized I'm going to have a problem.... (lowered vehicles enter)
Old Nov 22, 2000 | 12:27 PM
crazeinc's Avatar
Hey guys. I put on my Weld 15x3.5's Draglites last night and they've got 165R15's mounted on them so it's lowered the front of the vehicle just enough that there's just enough room to slide my hydraulic jack under there. I wouldn't mind cutting a coil off the front springs because I don't like the height it's at now, but that would put it too low to fit the jack under there.
For people with 2" drops, where do you jack it up in the front? The A-arms?
The '82Z
Hugger Orange
383 4 bolt main
3000 lbs
Bad cornering
NOS Sportsman Fogged
10 bolt braker
Coming to a street near you in the spring...
The car's website
[This message has been edited by crazeinc (edited November 22, 2000).]
Old Nov 22, 2000 | 12:35 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Crazyinc
With my 4cyl springs, and skinnies, I cant get m floor jack under the cross member. I have to use my scissor jack from my cavalier.It is a PITA.
Later
John
82 Firebird,355,Cam 224/234, .466/.488,TH350 Tranny,650 HolleyDP,Hooker Headers(I.E. POS) Manual steering
Best 8th et 8.62@80mph.
Old Nov 22, 2000 | 02:01 PM
Guest
Guest
Posts: n/a
Turn the wheel in one direction, and you can jack it up under the a-arm. You do that, put a large block or similar under the tire, do the other side, and then you can jack it up from the crossmember. I have to do this with my TA.
Old Nov 22, 2000 | 02:46 PM
crazeinc's Avatar
Spud...long time no see..you got me a manual steering box 8 months ago She's a beauty!
Old Nov 22, 2000 | 03:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's another way to get the jack under- lift the car up yourself!
Take hold of the front fender right above the tire, and lift up as hard as ya can. This will preload the struts- and they won't return to normal road height because you're not driving. They need to "bounce".
After you lift up one side, lift up the other in the same manner. Repeat this once more (left side, right side), and you should be able to slide a jack underneath the front. Works for me every time.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 22, 2000 | 04:29 PM
merf23's Avatar
I have a couple of 2x6's that i beveled the edge on. I just roll the car on these and then jack it up the usual way. Simple
Old Nov 23, 2000 | 09:06 AM
SeanSullivan's Avatar
I have a couple of wooden ramps that I use to drive up onto, they only lift the front 2 inches, but then its more than enough to get the floor jack under the front. Local handyman type made them in about an hr, $20 worth their weight in gold to me. I'm only lowered about 1 1/4 in the fronts.
Old Nov 23, 2000 | 09:44 AM
90IROCK's Avatar
i just jack mine in the center of the doors on the subframes brings whole car up at same time
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
