SHOULD i bump up the timing?
Old Nov 23, 2000 | 10:42 AM
IROC86's Avatar
hey, my lg4 has 0 degree timing and i thought that is kinda low. i have put a full exuast from headers to the cat back and i think i should bump it up to get more performance. how much should i bump it up and how can i do it on a computer controlled carb/distro. thanx guys
86 IROC LG4,DUAL SNORKEL,AMERICAN THUNDER,3.27 GEARS
Old Nov 23, 2000 | 11:08 AM
Vader's Avatar
IROC,
You should easily be able to get away with 6-8° BTDC with the right fuel. Since we're getting ethanol in the mix, a little advance should be acceptable without causing detonation.
Your ECM shouldn't have a problem with advanced base timing, since there isn't a crankshaft position sensor on your car. The only thing that will affect the ECM's control over the timing is the knock sensor input.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Nov 23, 2000 | 06:45 PM
IROC86's Avatar
thanks vader ur always helping. does anyone know how i should go about doin this. just turnin the distro right? i think i saw this once in some post so im gonna check thanx again
Old Nov 23, 2000 | 09:42 PM
Bort62's Avatar
Turn it Counter Clockwise To advance
You should hear the Idle Go Up
It dosent take much movement To change he timing alot, What I do is losen the Retaining Bolt and THen Hit that little block On the side of the Dist where the Tach plugs In with a wrench, only loosen it a little so You can just barely move it Or else when you try to tighten it, you can Bump it back very easily.
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
1992 Trans Am
May 10, 2023 07:19 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
86Base
Aug 8, 2015 01:34 PM
