rpms drop 500 while cruising
Old Sep 28, 2003 | 10:01 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I was goin back to college today and while cruising around 70-80 mph my rpms would drop 500 then go back to normal. I noticed when i hit the gas it would drop, when i let off it would return to normal. No SES light. No other problems. It would come and go.Right before the 500 rpm drop it would fluctuate 100 rpm or so.
What is it?
Knock retard or ignition problem?
Matt
Old Sep 29, 2003 | 01:33 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Maybe it is torqueconverter clutch that is locking,and drops rpm's.Could be some misadjusment at swith that is at brakepedal assembly.
Jari
Old Sep 29, 2003 | 12:15 PM
Matto'85TA's Avatar
Thanks. When you say switch at the brake pedal, what switch are you talking about? Shouldnt the tcc lock up earlier? Its a '89 305 TPI in a '85 TA. The '85 harness and ecm is still used.
O yea, the speed remains basically the same. Also, there is cruise control, but the wires are cut at the turnsignal lever, and i unhookd the cable from the throttle.
Thanks,
Matt
Old Sep 30, 2003 | 01:43 AM
z 28 jari's Avatar
Engine: 385
It is switch that controls cruicecontrol vacuum signal and torque converter clutch supply voltage(+12v).You can also measure controlvoltage at aldl connector(pin A=ground, pin F=tcc solenoid).
There should be 12v between A and F when engine is running and brakepedal is not pressed.When you press brakepedal voltage should drop to zero.Then drive car steady speed say 50 mph,and look that voltagemeter,when tcc lock-ups voltage shold drop near zero (about 100mV).
Jari
Old Oct 1, 2003 | 11:25 PM
Matto'85TA's Avatar
Could the TPS be the problem? What about bad main bearings or rod bearings? Or tranny problem?
Just some ideas. I have my reasons for thinking these things may be slight possibilitys.
Thanks,
Matt
Old Oct 6, 2003 | 08:23 PM
Matto'85TA's Avatar
ttt
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Eric-86sc
Aug 24, 2015 09:01 PM
Irocohio
Aug 12, 2015 08:03 AM
