Non or Self Aligning Rockers?
Old Nov 24, 2000 | 04:32 AM
AA89GTA's Avatar
Engine: 355 TPI
I am having my 5.7L TPI engine rebuilt, and I'm putting in a new cam, 1.6 rockers and AFR 190cc heads. Do I need self aligning rockers or non-self aligning rockers with the new heads? I've read that if you have guide plates, then you need non-self aligning rockers, but then I also read the opposite, so now I'm confused. Can some one answer this simple question for me? Thanks.
--Aaron
'89 Trans Am GTA 5.7
Old Nov 24, 2000 | 07:52 AM
FastBroker's Avatar
In general, if you DO have guideplates, you do NOT need self-aligning rockers because the guideplates do the aligning for you, get it?
Of course, you can use self-aligning rockers with guideplates but the excess cost is a waste.
Old Nov 24, 2000 | 08:50 AM
ede's Avatar
ede
if you're up gradeing to the guide plates you should need new push rods. the stock ones aren't hardened and you'll need hardened push rods for guide plates. you can check for hardened push rods with a file. a hardened one will not cut, or not cut easily.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 24, 2000 | 11:23 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
The guys are right...BTW, those AFRs come with guideplates so use non-self aligning rockers and hardened push rods.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Nov 25, 2000 | 02:12 AM
AA89GTA's Avatar
Engine: 355 TPI
Thanks guys...that's the way I thought it worked...Whew, I ordered the right stuff afterall! I did get new, hardened pushrods and non-self aligning rockers to go with the afr heads...thanks again.
--Aaron
Old Nov 25, 2000 | 08:17 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
Some cylinder heads have integral pushrod slots (allows negligible side to side movement) which you can use non self-aligning rocker arms w/o using guideplates.
Later
Matt
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
