how to know when fuel pressure is correct..without a dyno!
Old Sep 30, 2003 | 12:01 AM
martyr's Avatar
Car: 88 Formula 350
Engine: 357
Transmission: 700r4 Edge 2900 Stall
Ok....
TPS is perfect.
AIC is functioning. ( at least doesn't appear bad.) Just cleaned it!
Car stumble on startup and you have to rev it when cold..and shifting gears or it dies (embarassing.).
I have an AFPR and 24lb injectors. Running too rich or too lean???
If anybody has anything close to my setup maybe they can give me a good starting point.
Thanks for your input!!!
Old Sep 30, 2003 | 12:09 AM
demonchild's Avatar
just about everyone has your setup...and they all will tell you to try to make the acceleration feel the best, get your best time at a track, or keep checking your plugs and learn to read them really good, and then leave the fuel pressure at that point.
but since i dont have fuel injection, i would leave it up to the fuel injection gurus.
Old Sep 30, 2003 | 12:16 AM
martyr's Avatar
Car: 88 Formula 350
Engine: 357
Does seem pretty common doesn't it.
I'm heading up to Redding for the Street Drags on Oct. 4th. First time and all I'd like to make a good showing.
Is the fact I don't have my Transgo Shift-kit installed going to plague me? Should I shift manually or leave it in drive?
Soooo many questions and soooo little time!
Thanks for the reply.
Old Sep 30, 2003 | 12:29 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
WB 02 setup...
Old Sep 30, 2003 | 03:23 PM
demonchild's Avatar
wanna know some stuff about trannys, look for a guy named gmtech. also, i would try the tranny board.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
