Need help ASAP... flexplate just barely clears..can i still use it??
Old Nov 27, 2000 | 08:04 PM
z28cam100's Avatar
Car: 89 Trans Am GTA
Okay heres the deal...just installed the engine and tranny. Nothing is hooked up yet. Anyway the old engine had a 1 piece rear seal so i knew i couldn't use the flexplate on the newer engine (2 piece seal). I used the wheel that came with the engine... Now that its in it JUST barely clears the bellhousing on the 700-r4. this wheel is about an inch bigger than the old one. I thought that was the difference between the 2 kind...but now i don't think so..
Anyway will this flexplate work since theres only about enough room to put a finish nail between the wheel and the bell housing? I know that my new starter is for this flywheel so if i end up getting a differnt size will this starter work?
Please help me! i'm fearing having to pull this apart again
86 Camaro
305, T-tops, flowmaster exhaust, B&M shift kit
"Real cars are built, not bought"-some smart guy
http://hometown.aol.com/z28cam100/index.html
Old Nov 28, 2000 | 10:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like your new flex plate is the 168-tooth version, while your old one was 153-tooth.
The larger one will work; however, you'll need the other starter (the one you say you have, for the larger flex plate), and you'll probably have to enlarge the hole for it in the torque converter dust shield. Plus, since the starter will move out away from the block by about 1", it may interfere with headers. So you may want to come up with the smaller flex plate anyway.
[This message has been edited by RB83L69 (edited November 28, 2000).]
Old Nov 28, 2000 | 11:18 AM
Scott C's Avatar
I agree. Do it right the first time while you still have the option. You''l kick yourself later for not fixing it now. Get the proper size flexplate and use the existing starter.
Old Nov 28, 2000 | 02:15 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
yep, ur gonna definately wanna ****** up a smaller 153 tooth flex plate... gonna be the best for your app
Steve
Old Nov 29, 2000 | 07:12 AM
Pat Hall's Avatar
Steve
The smaller flexplates for the two piece cranks are so common, you might trip over one when you enter a junkyard. They came on a lot of the two piece 305's in the mid to late seventies cars. Should be a piece of cake to locate one!
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Nov 29, 2000 | 02:46 PM
z28cam100's Avatar
I already got one from autozone...26 bux. thanks for your help guys!
86 Camaro
84LsxZ28
May 17, 2020 02:21 PM
RedLeader289
May 28, 2019 01:47 PM
Fanatic1074
Oct 2, 2015 03:47 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
