HEI Distributor Experts??
Old Dec 2, 2000 | 01:10 AM
sguy30's Avatar
I just finished replacing the intake manifold gaskets and was about to put the distributor back in when I noticed it was very hard to rotate. Seems like something is frozen inside. I checked my chassis manual and there doesn't seem to be any info on how to rebuild it. Are there bearings/bushings I can replace to remedy my problem or will I have to go and get a new one? As a side note, the top of the distributor is very rusted.
'87 IROC, 305TPI, 5Sp, , 170K miles, all original except for K&N filter, Vin F
Old Dec 2, 2000 | 01:17 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I just saw a topic the other day that had you answer! There are bushings in there that wear out, but it sounds like your's are galling from a lack of lubrication. I'll see if I can find the topic again.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Fanatic1074
Oct 3, 2022 05:57 AM
skinny z
Oct 5, 2015 06:23 PM
djmarch
Oct 2, 2015 10:41 PM
Damon
Sep 26, 2015 04:29 PM
