Hair brained scheme!! (lol)
Old Nov 30, 2000 | 10:29 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
How bout this one
is the smog/AIR pump just an over weight unneccessary peice of junk or could it be used for something more... hairbrained
what about hooking it up to the throttle body coolant passages to intercool incoming air.
i think by far this is the most rediculos thing i have come up with for the tpi setup yet so DONT try this unless you want to get laughed at (like I will in this post).
still... the smog pump does have some interesting possibilities...
Old Dec 1, 2000 | 12:52 AM
Bort62's Avatar
The Volume isnt Enuff
Trust me, Ppl have tried
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
Old Dec 1, 2000 | 12:55 AM
JPrevost's Avatar
Car: 91 Red Sled
That seems like a good idea though. Thought is what counts.
Old Dec 1, 2000 | 11:57 AM
jrr's Avatar
jrr
True story:
The AIR pump on my Olds 88 parts-gofer / beater is connected to a tube, that goes back to a "T" fitting and through the star-wheel adjuster hole, for both back brakes!
My original theory was that it might help keep the drums cool. I'm not sure if it makes a difference there, but the innards are clean and almost dust-free.
Old Dec 1, 2000 | 02:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow, both those ideas are amazing! I never would've come up with that. I like the brake cooling idea
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 1, 2000 | 05:05 PM
Blade's Avatar
How about if you route a hose from it to over the dipstick tube. That way it will blow air into the crankcase to keep your oil cool and well aerated... ROFL!
Old Dec 1, 2000 | 05:44 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
i think i've got you topped.
try a pulley 1/3 the size of the original off a tauras alternator, drill it to bolt to the air pump, rout the air through some fat heater hose to the intake and you've got yourself a supercharger.
the downside is that after 5 seconds the air it blows is like 200 degrees, and now your car sounds like a really pissed off lawnmower. besides it threw the pulley off in a few minutes.
This goes to show what you can come up with when your really bored.....and stupid!
the scary part is that the car actually felt quicker for the first 5 feet!
i can just hear you laughing.
88 CAMARO RS
87 IROC-Z DRIVETRAIN
305 TPI, 700R4, 3.73s
ported plenum, performance resource chip,edelbrock TES Headers and cat-back, K&Ns, AFPR, rest is stock.
15.0 @ 92.5 (bald tires)
Old Dec 1, 2000 | 09:17 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I actually thought of making it into a charger but i figured it would heat up like nobodys buisiness if you overdrove the pump.
I still cant belive someone actually pulled it off though.
If you think these Ideas are nuts try this one on for size.
I once thought about taking an electric leaf blower and sticking it on my intake tract and then hook a speed controler up to the blower and control it from the tach or an msd or something. I still wonder if this would work. it seems like such an improvement over mechanically driven blowers because there is no HP loss to the blower.
oh yea BTW--- DONT TRY THIS.
Old Dec 2, 2000 | 01:25 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The leaf blower has been tried! I remember hearing about it a few years ago!
My idea was to run a small A/C evaporator under, or in the intake to help cool the intake charge, similar to what Nitrous does, but obviously not as much all at once.
I still wonder about this one! The parasitic draw would prolly be more than the gain though. Damn it!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Dec 2, 2000 | 01:41 AM
bman's Avatar
i think gm originaly designed them to hook up to the valve cover to create a vaccum in the crank case but forgot to hook it up the right way.
it actualy frees up a few hp in a high rpm race motor.
Old Dec 2, 2000 | 04:28 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Thats not as goofy as my smog-pump supercharger idea (too much beer and free time lead to bad things...). Hehe dont even think about it, it doesnt pump nearly enough. BTW, who says, the air out of the smog pump is cool? It sucks it in from the engine compartment. And blade, lol I can jsut see your oilpan gasket blowing out with that idea
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
[This message has been edited by Ward (edited December 02, 2000).]
HoosierinWA
Oct 7, 2015 10:15 AM
Numbah-1
Oct 2, 2015 08:27 AM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
3.8TransAM
Sep 27, 2015 08:37 PM
