HELP!!
Old Nov 25, 2000 | 03:33 PM
pat85yellowroc's Avatar
HELP!!
for the last week or two, from time to time, when i would go to start my car,intstead of starting, idling at 2K for a few seconds and dropping down nicely,it would start and then almost die immediately. whats the deal?? i need my car. help is greatly appreciated.
beau-t-ful yellow 85 iroc
Old Nov 25, 2000 | 04:11 PM
Ratnose86SC's Avatar
If its carbed, your choke is leaning out too much.
Old Nov 26, 2000 | 01:12 AM
sorry, it normally goes up to about 1500, not 2000. its TPI. please help.
Old Nov 26, 2000 | 10:07 AM
Vader's Avatar
Pat,
Have you cleaned the IAC and air passages lately? That generally helps with erratic idle speed problems.
If your engine refuses to run at all after cranking, you might have a fuel delivery problem. It's possible that you are starting on the fuel sprayed by the cold start valve but are getting no injector pulses once it's running. Need more info on the exact symptoms, please.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Nov 27, 2000 | 10:38 AM
well, it doesnt do it all the time. from time to time, when i start it up, it will start and barely run. it will start and automatically be running at like 500 rpm. doesnt do it all the time though. thanks in advance.
Old Nov 28, 2000 | 07:20 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Pat,
I just had a prob just like that with my car, It would crank up and do the same thing and almost die right after starting. Also if it wouldn't die it would idle high and low, high and low before running normal. As Vader said try cleaning your IAC. If it doesn't fix your prob then try to replace your MAF relay. That was the prob with mine. I would recommend replaceing the relay before any parts because its alot cheaper. Oh by the way I m not sure what relay it would be on your car. But on my car I have a 89 tpi it was the second relay on the driver side. I hope that this was some help for you.
Old Dec 2, 2000 | 01:45 PM
what should i clean the iac with? tb cleaner? what does the maf relay look like and where exactly is it? today it wouldnt start at all.
