SBC 400 with a "MILODON DIAMOND STRIPPER" WINDAGE TRAY
Old Oct 13, 2003 | 08:37 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I have a SBC 400 with a "MILODON DIAMOND STRIPPER" WINDAGE TRAY. I read that it needed a little messaging to get it to fit a SBC 400 with enlarging the studs holes. Now the problem that I have is my ARP Studs designed for windage tray only have 5 long studs on main cap 3, 4, and 5 (rear main cap). The Diamond Stripper tray has 7 holes. Will it be feasible to mismatch the Milodon Studs kit with the ARP Studs?
Next Situation
The Windage tray end that is suppose to mount to the Stud on the Rear Main Oil Pump Cap is centered over the oil pump stud. Has anyone using this windage tray on a 400 drill a hole to match the stud on the main cap or used the oil pump stud to mount the tray. If anyone have any pictures of this modification on a SBC 400 please post or provide a link.
Thanks: David
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
