more hp!
Old Oct 14, 2003 | 03:45 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
more hp!
Hi guys,
Ihave an 85 TA with 305 155 hp(engine code H). Want to add some more hp without an engine swap. I am still going to drive almost daily(in summertime) so I dont want anything extreme. 200+ hp would be nice. What parts should I go for, and in what order? I have a limited budget and must do this step by step so to speak. In what cases must I get a new custom computerchip and where can I get it? I live in Sweden so I wont be able to bring the car.
excuse my bad english
Grateful for suggestions.
Old Oct 14, 2003 | 04:32 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
my 85 t/a came 215hp stock.
i guess you can look for some of those model heads (not sure which #), cam, headers.
tpi?
descreen the maf, tb coolant bypass, little bit of porting, take out the ac and smog pump...that should net you 30-40hp easy.
Old Oct 14, 2003 | 05:59 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
how's he going to descreen a maf and do a t.b. bypass on a carbed engine? i'd look into the basics, but to get over 200hp, you might as well buy a cam to start with. other than that, headers, intake, catback, carb work, timing change, 160 thermostat, etc. good places to start.
Old Oct 14, 2003 | 06:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Exhaust first, all the way form the heads to the street. Get a chassis-specific system (not a "universal" one) for one of these cars, but NOT for a LG4 car; get one for something like a 88 350 TPI Camaro.
After that, a cam.
After that, better rear end gears, such as 3.42s. Sometimes things other than the engine itself will make a car slow.
Old Oct 14, 2003 | 06:22 PM
zippy's Avatar
Engine: 5.3L
i was going to mention the gear part also along with shift kit and converter, but thinking it may be a bit much to go into at once. :lala:
Old Oct 17, 2003 | 04:42 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I see you are from sweden, check out www.tacs.nu There are several guys who can help you in sweden.......
/N.
Old Oct 17, 2003 | 08:00 AM
Steve89GTA's Avatar
Just save your cash and buy a crate motor!!!
Old Oct 17, 2003 | 06:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
RB has you on the right track. (Steve, that wasn't much help - he specifically said he didn't want to go that route, and his goals don't require it).
Only thing I'd add to RB's suggestions is air cleaner. That single inlet thing is a power killer. Just putting a dual-snorkel and exhaust upgrades per RB's suggestions will make a substantial difference. Oh, the carb secondaries need tuning with rods & hanger.
You don't need to do anything to the chip.
The combination in my signature translates to about 250 rear wheel HP.
