Free 327!
Old Oct 14, 2003 | 06:05 PM
killer305's Avatar
Free 327!
i got a 327 short block a couple months ago and im trying to decide what to do w/ it.
This is what i know for sure:
It has lt1 pink rods
Forged speedpro pistons
Bored .40 over
This is still up in the air.
The box the crank is in says it a LA Billet Crankshaft. I know its not cast cause it rings like a bell when you tap it.
The block has rust (not too bad) and needs new cam bearings (i had to pull the rear freeze plug and pound the cam out. There is also a chip missing next to one of the rear main seal bolt main blot holes.
So my question is is this worth building or selling. I would raise the compresssion of my vortec heads to 10.5 to 1. and would loose the ****ty 305.
I was thinking about running nitrous on the 305, and if it blows i would have a 327, with hopefully a realy strong bottom end to shoot more nitrous.
Old Oct 14, 2003 | 06:29 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
damn... from reading the topic title, i thought you were giving it away.....
Old Oct 14, 2003 | 07:07 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
For real I could use another 327. If theres rust on the cylindar walls and its already .40 over I wouldent use the block if it were a large journal. Find another donor block with a 4in bore AKA 4 bolt 350. Core blocks usually run $100 for a 2 bolt $150 for a 4 bolt If its a large journal 327. Either way it will produce more power then your 305.
Old Oct 14, 2003 | 08:37 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i gave away my last one too.....
Old Oct 14, 2003 | 10:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Can someone give one away to me?
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
TexasFormula
Sep 30, 2015 06:36 PM
FueledSoul
Sep 26, 2015 12:00 PM
