*Which Brand of Ignition Module To Get*
Old Oct 18, 2003 | 08:04 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
Ok its time to get a new modlue. Which one do you guys prefer. I was thinking of getting a gm replacement one.
Old Oct 18, 2003 | 08:22 PM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
The MSD HEI kit is a good way to go. It includes the module, coil, distributor cap and rotor. It is part number 8501. It is not the cheapest way to go, but it is on of the best ways to go. Don't forget a good set of plug wires. MSD makes a set of over the valve cover wires with all 90 degree ends under part number 3135 for blue, 31353 for black,and 31359 for red. A new set of plugs and this should take care of your ignition woes.
Old Oct 18, 2003 | 09:27 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Accel. Cheap, avalible, work fine.
Old Oct 18, 2003 | 09:50 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ditto
Old Oct 18, 2003 | 11:49 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Proform. Cheaper than the others and works great
Old Oct 19, 2003 | 07:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: *Which Brand of Ignition Module To Get*
I agree with your choice. The GM module is the best of all.
RBob.
Old Oct 19, 2003 | 08:31 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: Re: *Which Brand of Ignition Module To Get*
RBob.
Same Here. My accel lasted only 3 months before it fried. And yes I did use the greese underneigth it.
pjsparts
Oct 29, 2025 06:39 PM
J-money
Jan 4, 2019 09:45 AM
SG91camaro
Sep 5, 2015 10:27 PM
middian
Sep 5, 2015 01:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
