What to do to keep your car in good condition from street racing??
Old Dec 6, 2000 | 08:58 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
How do u keep your car in good tune from street races and running at the track?? Thanks!!
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Old Dec 7, 2000 | 02:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'm not sure I understand the question.
But a general way to keep your engine in good tune is check the spark plugs for fouling, check the wires for burn marks or cracking, make sure your timing is set correctly, check the cap and rotor for wear, replace your fuel filter and O2 sensor every 10-20,000 miles, check your exhaust for holes or rust, etc.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 7, 2000 | 06:15 PM
SeanSullivan's Avatar
I road race mine 8 times a yr at Hallett, I would also recommend changing the oil more frequently than 3000 miles. This provided you do race it full out. I change mine before and after each race. I also lube all fittings. I have a 115K miles on the engine that I raced this past yr, not one bit of trouble mechanically in that engine. No loss of oil or pressure either.
9192camaro
16
Feb 3, 2019 12:21 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Reborn756
Sep 4, 2015 03:42 AM
z28addict8490
Aug 7, 2015 08:48 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
