What to do?
Old Dec 7, 2000 | 08:43 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
What to do?
Need opinions....
Should I go for a 383 or a 355 when I do my rebuild? All internals will be forged and comp. set to 9.3. I will keep my other mods (se sign) and probably add a ATI 9psi kit in the future (I hope....).
What kind of power will I make with just the 383/355 without a ATI.
Is it possible to hande the power I will get from a SC 383.
Tha car is a daily driven....
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Dec 7, 2000 | 09:41 PM
Dan87IROC-Z's Avatar
I'd go with the 383, its just as streetable of an engine as is the 350 and 355 and it will make more power.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
