Sticky Piston
Sticky Piston
My '86 305 camaro sat for about three months, then I started driving it, I noticed that when I start it it runs really hard for about 5 min. I took it to a friend who hooked it up to a machine that said my forth piston is sticking. I was told that since it sat for so long it my take a while for the rings to reset, should I assume this is the case?
your rings may have stuck in place, but a little oil and running the engine should free them up fairly quick. the piston isn't getting stuck and then freeing it's self as the engine spinns.
-=ICON MOTORSPORTS=-
1st & 3rd
1st & 3rd
Car: 89 IROC
Engine: Yes
Transmission: That, too.
Now, I have heard of lifters getting sticky after sitting in sludge for too long, and a sticky lifter may make the valve operate in a slightly sluggish fasion. Normally the best cure for any of these problems is to do several oil changes at increased frequency to help dissolve out the varnish buildup.
Two words - synthetic oil.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Later,
Vader
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Please elaborate on what you mean by running hard. Do you just mean at high RPM's? If your car is carburated, it would be normal for it to idle high until the choke is open (I hate that about my car!)
Vader, Would the synthetic oil break the varnish up quicker? Also, the question has been asked over and over about changing to synthetic with high miles, well how about going to a blend for a couple oil changes, then to full synthetic? Would this help the seals, etc.. "get used" to the synthetic? Just a thought!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Working on:
'84 Z28 LG4 305
145 MPH IROC Speedo
Building 430 HP 350
Block is in shop!
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
Dragonsys
Sep 25, 2015 03:51 PM
