stutter
Old Oct 26, 2003 | 09:54 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
stutter
92 5.0L 5spd throttle body injection. Car stutters when it starts moving and then will suddenly start moving like nothing happened. never dies though. It goes away after a few stop and goes than runs fine. Ignition is all new so it's not that.
Old Oct 26, 2003 | 10:35 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I dont know if its the same for the manual cars as it is for the autos but take a look at the idle air control valve. If it sticks partially closed or is sluggish, it will cause the engine to bog down on throttle tip in because the fuel mixture will be momentarily very rich. I had a similer problem as well when the bearings in the rear of the IAC froze solid and it got stuck in one position. Try cleaning the IAC and see if it helps. The procedure has been covered here before so do a search.
racereese
Oct 3, 2015 03:46 PM
89BlueTA
Mar 14, 2002 06:00 AM
Night Hawk
Feb 19, 2002 07:20 AM
Night Hawk
Feb 17, 2002 06:57 PM
