How difficult is it to replace a fuel pump?
Old Oct 27, 2003 | 10:22 AM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
The other night my fuel pump gave out on me and I was wondering how difficult they are to replace and if any special tools are necessary. Thanks.
Old Oct 27, 2003 | 10:26 AM
ede's Avatar
ede
i'd say not hard but a pain in the ***
Old Oct 27, 2003 | 03:26 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Ede is right, it's a real PITA!
If you plan on keeping the car, and are not afraid to customize it.... do what I did. I cut out a square (10*10) on the floor board just above the gas tank, and custom fit a 'trap' door on some new sheet metal.
Works like a charm, and the need to drop the entire rear to get to the fuel pump is now a thing of the past. :lala:
Good Luck
Old Oct 27, 2003 | 04:07 PM
MdFormula350's Avatar
i would just drop the tank and spend roughly 3 to 6 hours on your back, good time to clean around the open tank area, and look for any bad area in the body or tank itself.
handtools, jack, stands; thats all you need really.
the hardest part most will say is getting the gas out to make the tank easier to move around.
Old Oct 27, 2003 | 08:19 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
The only special tools I used when doing my fuel pump was a lift. Boy that made it easier!!!
It is not that bad, took me about 5 hrs for the first one. I had to remove just about everything in the rear. Maybe a can of rust penatrant handy would help on some of those stubborn bolts...
Old Oct 27, 2003 | 08:41 PM
llvll4l2c91350's Avatar
https://www.thirdgen.org/techbb2/sho...ight=fuel+pump
cutting a hole wasn't an option for me.
Old Oct 27, 2003 | 08:57 PM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
I should have added that cutting a hole in the frame is dangerous, and that when I made my trap door, I did this when my tank was already removed from the vehicle....
NEVER cut and weld with the possibility of a fuel leak near.
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
