Took out Smog Pump... have a Question...
Old Oct 28, 2003 | 07:57 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
alright... i just finished taking out the smog pump, but what do i do with all those hoses? here's a pic i took of the passenger side of the engine bay... can anyone tell me what to do with the rest of the smog stuff here in the pic? thanks guys
Old Oct 28, 2003 | 08:04 PM
Potato's Avatar
The hoses have a bracket bolting them to the back of the heads. Remove this bolt and pull the hoses off. Your A.I.R. lines will still be connected back at the catalytic converter so they will need to be removed in order to pull the lines completely off. Also, you'll need(I believe, someone correct me if I'm wrong) 1/4" pipe thread plugs to plug the connections were the A.I.R. lines went into the manifolds.
Old Oct 29, 2003 | 07:37 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
yes 1/4 .
also you can buy a cheaper set of headers. that is what i did sice i don't need the air tubes!!!
jaridjohn
Oct 5, 2015 07:01 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
