More a/c removal questions, yes i looked in the archives
Old Dec 15, 2000 | 12:27 PM
86Trans Am's Avatar
A couple of easy questions, yes/no maybe...
for now i dont really care about having the holes in the box on the firewall, i have v-belts, so i dont need a delete pulley, so is there anything else i need?
will my vent still work, hot and cold?
will the heater still work with no other modifications?
and if i take the whole sysytem out, i dont have to have the freon drained correct? Just unbolt everything that is holdign the system in and lift it out, right?
thanks
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Dec 15, 2000 | 02:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1. Yes.
2. Yes.
3. Yes. You can remove the top of the evaporator housing (about 6 or 7 screws) and just lift the evaporator out, without having to cut or otherwise do anything brutal. Then you can just put the housing top back, and cover over the holes where the evap lines went through it with something. The whole system can be lifted out as a unit (it went into the car that way in fact).
Old Dec 15, 2000 | 07:52 PM
86Trans Am's Avatar
Thank you very much.
1986 Trans Am
305 TPI
bigben85
Sep 13, 2015 10:12 AM
BikeFarm
Aug 11, 2015 11:35 PM
L98GTA87
Aug 11, 2015 06:55 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
