Crane 2040 and 1.6 Rocker Arms
Old Nov 3, 2003 | 04:59 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
Need a little advise, please.
I have a 355 cid TPI engine with stock heads and flat tappet lifters. Currently it has a PowerMax 2040 cam and 1.5 rocker arms. I have a new set of stamped 1.6 rocker arms I'd like to install and wondered if someone had already tried this? I'm concerned about whether or not I'd suffer from valve spring coil bind or any other disastorous side effects. Installing the new engine on Wednesday and was hoping to have an answer by then.
As always, thanks for any advice you may have on the subject.
Old Nov 3, 2003 | 05:42 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Axle/Gears: 370 BW
If this helps, here are some cam specs.
Thanks again!
Lift:
Intake @ Cam 2934
Exhaust @ Cam 3027
Intake @ Valve 440
Exhaust @ Valve 454
Duration:
Intake 270
Exhaust 276
Old Nov 4, 2003 | 09:38 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
if you have the stock springs, i wouldnt recommend it.
Old Nov 4, 2003 | 09:43 AM
ede's Avatar
ede
make sure you replace the old rockers with the same type, either SA or nonSA. you can't mix and match
Old Nov 4, 2003 | 11:10 AM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Axle/Gears: 370 BW
Have an extra set of heads, guess I'll wait until they've been ported and polished and replace the springs and rocker arms at that time.
Still if anyone has been successful with that combo let me know.
Appreciate the feedback.
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
