a/c compressor
Old Nov 5, 2003 | 05:24 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
a/c compressor
is my a/c compressor supossed to try to cycle when the heat is on? not sure if its called cycling but i thought i may have heard thats what it is. anyway, when the heat is on and the car is at idle the compressor clicks and the rpms raise as if the a/c was on. now it just doesnt stay there, it clicks on rpms go up. a few sec. later it clicks off, rpms go down to normal. my a/c works great for having never been charged before. but since its almost winter it wouldnt bother me to disconect the compressor if i have to. so if thats what you would recomend which of the two plugs on the compressor need to be disconected? btw, if its supossed to do that, that sucks cause its damn annoying...lol
Old Nov 5, 2003 | 06:03 PM
85TransAm406's Avatar
Car: 1985 Trans Am
No, it shouldn't be cycling. It should only cycle when: selector lever is in the AC position, or in the defrost position. If you can't figure it out, disconnect the flat connector near the front, the smaller round one is for the AC compensator circuit (tells the computer to idle up when AC clutch has power and is engaged). make sure your selector lever is working good (blowing out front vents, floor only, and defrost). It might be stuck in defrost if it doesn't do that, engaging the clutch.
Old Nov 5, 2003 | 06:43 PM
Car: 91 RS
Engine: LO3
thanx. it does it no matter where its at, floor, vent, defrost. the slector does work, it will actuate the vents, floor, etc. but the compressor cycles in all positions. oh well, ill just disconect it for the winter. thanx again
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
Ironhead38
Sep 7, 2015 02:26 PM
