WHEELS
Old Dec 18, 2000 | 01:02 AM
CAMARO-90-RS's Avatar
WHEELS
I HAVE A SET OF P23560R15 TIRES AS THE REAR WHEELS OF MY CAR. I WANTED TO KNOW HOW CAN I SAFELY MAKE MY TIRES STICK OUT AN EXTRA
1 1/2 TO 2 INCHES
Old Dec 18, 2000 | 01:21 AM
Vader's Avatar
90RS,
You can get wheels with a greater positive offset, or get the same offset with wider wheels and tires. There is generally more space on the inside area than the standard 15" wheels take up, so wider wheels are fairly easy on the rear. The offset on teh front end is a bit different, since the track is a bit wider. If you want a little wider stance on the rear, you can install a pair of front 16 x 8" wheels from a ThirdGen on the rear, since they already have a bit more positive offset. The fronts and rears are different in the 16" sizes, by a little over an inch.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
