So much for ideal Quench.....Are these numbers usual?
Checked piston to deck clearance w/ a bridge and dial indicator.
I took a measurement just above the cylinder on the block, and just below the cylinder on the block. Then took a measurement of the piston center. I averaged the 2 bigger numbers, and subtracted the piston numbert to get my depth of the piston in the cylinder. Did this for Cylinders 1, 2, 7, & 8. See results below with an example...
Cylinder #8
Top, just above cylinder... 0.296" registered on the indicator
Bottom, just below cyl......0.287" registerd on the indicator
Avg those 2 numbers ......0.292"
Piston raised the indicator 0.204"
0.292-0.204 = ~0.088" depth of piston from deck at TDC
Cylinder 1 = 0.091"
Cylinder 2 = 0.091"
Cylinder 7 = 0.094"
Cylinder 8 = 0.088"
With 0.025" the standard number thrown out around here for typical stock piston to deck height...
I double checked what I did.
Any ideas why the numbers turned out like this? Gasket material is removed. Used center of piston...hmmm... Should I have used the edge of the piston? That might make up the difference.
EDIT:
Nevermind. Used rim, edge of piston. # 1 piston came out to .026" doing it that way (0.268" measured on idicator). I reckon that's how you do it.
LOL. GM flat top pistons
Cylinder #8
Cylinder 1 = 0.091"
Cylinder 2 = 0.091"
Cylinder 7 = 0.094"
Cylinder 8 = 0.088"
EDIT:
Man, you had me all ready to ask where you were measuring from. Many dished pistons have the tapered perimeters, which would result in some pretty deep indicator point penetrations. I was thinking "Almost .300"? What kind of rods are in that thing?"
Thanks for the update. Were you using a really small point on the indicator, like a BesTest?
3.8TransAM
Sep 27, 2015 08:37 PM
tcflint
Sep 27, 2015 05:58 PM
