fuel pump probs, plzzz help me
Car: 1989 RS Camaro
Engine: V6 2.8 liter
Transmission: manual
I have no idea where my fuel pump is, and im almost 100% sure its an electric fuel pump, but i was wondering, some1 told me my fuel pump was inside of my gas tank, and i have a 1989 RS 173 v6 2.8 liter engine, sooo if u kno where it is and if in the gas tank then how to get to it to replace it then help me plzzz
Car: 1985 Iroc-z
Engine: 355 sbc
i don't know about a v6 but i bet its TBI which means the fuel pump is most likely in the gas tank...
easy job, jack the back end up, you'll see two straps that hold the tank on with bolts... have the jack hold the tank up and it was really easy with two guys, but not necessasy...i think there is 3 lines coming out of the tank... you may even be able to replace the pump without disconnecting the lines..
if u do replace it, get a good pump, not a cheapy...especailly if u want to keep the car... i know on some "carbed" v8's the pump is located on the side of the engine passenger side, trace your fuel lines... if you see nothing by the motor, assume its in the gas tank...
Car: 1989 RS Camaro
thnx
ok, but in my booklet it says that i hate to drop my rear end to take it out, is this true, and i think it is, becuase the gas tank is wedged in between 2 peices of metal where u pump the gas , but is there i was i can change it as is with it just hangign there????, and also what kind of pump, where do i buy it, and how much will it cost, cuz i kno can get a stock one for like $73, but i want something high proformance that will make my car run better, thnx ne ways
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
you car should be fuel injected.. as far as a proformance pump there really isnt any need for it.. it wont make your car any faster, all you need is a pump that is capable of reaching and maintaining the required pressure (basically a stock pump), as far as dropping the rear yeah you need to so you can get the tank out, it might be possible to somehow just lower it enough and squeeze it in there somehow but i've never heard of anyone doing it, some people cut an access panel above the tank and do it that way and weld it back, personally i'd just do it the right way and drop the rear, your call, if you do it on a lift you can leave the lca's connected and just drop the rear low enough so the tank can clear... good luck!
edit: why are you replacing the pump anyway?
Car: 1989 RS Camaro
im replacing my fuel pump because it went out recently, it might just be clogged, but im almost 100% sure it went out, but yah im probly just gonna drop the rear end, and do it the right way first, but thnx anyways for helping me out
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
