Sorta to Vader
Old Dec 19, 2000 | 01:56 AM
Enkil's Avatar
Sorta to Vader
In another post I believe, you said that in a TPI engine, the electric fan was cut on by grounding a wire. (The green one with a black stripe I believe.. ??) Does it work the same way in TBI engines? I'm going to wire a switch to the fan and just want to make sure it'd work the same before I go cutting into anything.
89 iroc-z
everything stock, except for a mirror that fell off
Old Dec 19, 2000 | 02:51 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i clipped my grey wire just before the relay. connected some wire to each end of it and routed it to the interior and threw a switch on it. just be careful with this....dont short it out on a screw or something like i did. this grey wire is the one that goes into the alternater...and if you short the switch you could blow the fuse, fusible link, and/or alternator. that only happened to me cuz i didnt mount the switch...its just hanging there. hope this helps. rick
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
3.1 firebird
Mar 4, 2001 08:57 AM
rsilver
Dec 12, 2000 09:12 PM
