IAT Maintenance
Old Nov 13, 2003 | 09:37 PM
CamaroRS91x's Avatar
IAT Maintenance
Is there a way to clean the IAT? And what are the symptoms of a bad IAT? Thanks
Old Nov 14, 2003 | 09:04 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Idle air temp sensors sit underneath the plenum on the TPI cars. If it is bad, there's no way the ECM can tell the air temp entering the engine, and won't know how to mix the air and fuel. You could remove it and clean it with a wire brush, but you'd be better off replacing it. If the IAT is bad the car will probably run rich, along with the SES light coming on as well, perhaps setting an engine rich code.
djmarch
May 8, 2016 11:32 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
86White_T/A305
Sep 21, 2015 05:28 PM
