converting to non-EGR
Old Nov 14, 2003 | 02:05 AM
mastertrixter's Avatar
Car: 82 z-28
Engine: L69
Transmission: muncie T-10
alright guys, what all encompases converting my new engine (an l69 out of a monte carlo) to a non-EGR setup. Is it simply putting on a non-EGR manifold and getting rid of the tube that runs up to the EGR, or is there more to it?
thanks
cody
Old Nov 14, 2003 | 04:30 AM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
you don't have to get a new manifold. just bolt a block off plate (a piece of sheet metal) to the egr hole in your manifold, and take out the tubing. for TPI anyway.
You'll be throwing the EGR code all day long though.
Old Nov 14, 2003 | 06:59 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
I used a piece of an older exhaust manifold gasket (the methalic section, obvious) as a blockoff plate, but the BLM's were more lean and the combustion chambers were overheated. Finally; I went back with this project.
Since the error code was disabled in the PROM, no problem with this.
Denis V.
Old Nov 14, 2003 | 03:23 PM
Car: 82 z-28
Engine: L69
error- i'm already going with a new manifold, part of my little build up. and the ECU is going bye bye. So no worries there.
thanks guys,
cody
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
