Torqe Specs
Old Nov 14, 2003 | 06:16 PM
assassinx1's Avatar
Car: 92 Camaro RS
Transmission: 700 R4
Torqe Specs
I was wondering what the torque spec is for the crank shaft gear and the cam shaft gear is for a 92 305 camaro ...i have t do a timing chain this week end
Old Nov 14, 2003 | 06:55 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Camshaft gear....... 20ft. lbs.
Vibration Damper-to-Crankshaft Bolt ...... 60 ft. lbs.
You should be able to find a lot of torque specs @
www.torquespecs.com
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
angel2794
Sep 8, 2015 06:22 PM
