need some quick help with vseals
Old Nov 15, 2003 | 04:50 PM
grndmasnightmar
Guest
Posts: n/a
ok im working on my car today and sunday is when i need to be done but i have a few last min questions so someone please give some advice. im doin the valve seals on my stock tpi 350. some people said unless machined for it heads cant take positive seal. well i think i have stock heads and when i took off the springs the intake had positive. they looked in good shape but the bottom was a little deformed, stretched whatever you want to call it. is this normal wear? also i put positive on the intakes that i already did is this ok for a stocker? also i put new pushrods in and i wanted to know when the slip into the hole how do you know there properly positioned, is it just as simple as if its wrong your arms wont line up and if its right they will?also when the keppers go back on is there anything you need to do to reseat them or is it just if theyre in the right spot they will hold the spring and be flush. and the last concern is im setting the valve lash the way chiltons says, certain valves when at 1 and 6 degrees. should i be confident that when im done my car will start with no claking and all because id hate to have to pull the covers again.
Thankyou anyone please answer i need to know tonight
Old Nov 16, 2003 | 07:09 AM
ede's Avatar
ede
you can use positive seals i use both positive and o ring. you can tell when a push rod is in the lifter cup by spinning it, if it spins your good if it isn't it'll move around. i smack the valve with a brass or soft hammer to make sure everythnig is seated before i put the rockers on. i measure the distance from the stud top to the top of the nut and replicate it when i reassemble, no need to do any adjusting then, or only minor adjusting. follow your manual and you ought to be in good shape. i'd leave valve covers off to make any finial hot adjustments.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
