How to install a Grant Steering Wheel?/Remove stock 1?
Old Dec 23, 2000 | 07:14 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
how do i remove the stock steering wheel. i know ive seen a tech article around somewhere...about disconnecting the batt, fuse, and 4 bolts behind steering wheel...cuz of the airbag...but what else do i do? thanks so much
90 rs
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Dec 24, 2000 | 12:08 PM
ede's Avatar
ede
you'll need a tool to compress the lock plate and a puller to remove the stearing wheel. for the grant i've never put one on, even thought 2 of my cars have them.
ICON Motorsports
1st & 3rd
Old Dec 24, 2000 | 06:57 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
the only special tools you will really need are a steering wheel puller (you can rent one from most parts stores like autozone) and a pair of snap ring pliers to get the snap ring off the bolt.. pull your horn cover off, remove the small bolts, remove the center nut and use the puller to pull the wheel.. installtion of the new wheel is pretty straight foward and the install kit (yes, you need a install kit to install grant wheels.. the kit has everything youll need to install and some good detailed instructions...
Old Dec 24, 2000 | 06:58 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
der.. i musta read over the part where you have a airbag.. grant does make some wheels that retain the airbag for a little more money.. as far as using a wheel without a bag im not sure on this one...
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
